Highlighted
Occasional Contributor I
Clearpass Medical Device fingerprints
I was in the process of building some custom fingerprints for Medical Devices on our network, and i noticed something odd. We have 79 fingerprints currently in the "Medical Device" category, mostly system defaults with a couple custom ones. However, devices 1-75 have Device Family names starting with A-H. After H, I only have 4 other fingerprints. Am I missing a bunch of fingerprints? It seems odd that I would only have 4 known fingerprints of Medical Devices with Device Families beginning with I to Z, when there are 75 beginning with A to H. Are others seeing the same counts in their installations?
Accepted Solutions
Highlighted
Re: Clearpass Medical Device fingerprints
I'm seeing the same numbers.
Cheers
James
View solution in original post
All Replies
Highlighted
Cheers
James
Highlighted
Thanks for responding, now it's off to Aruba to see why the category seems half-finished.
