Clearpass VM IP issue
Running Clearpass 6.7.3
VM is running on Hyper-V 2012.
Issue is after i configure the ip and the machine reboots it looses the ip config.
i have 2 nics one is disabled.
Any thoughts?
Re: Clearpass VM IP issue
Can you have both the NIC's enabled, Just to ensure that we are configuring the IP on the right NIC.
i have just changed the NIC setting and still the same issue
Just referring to "Installing or Upgrading to 6.7 on a Virtual Appliance" technote.
Supported Hyper-V Versions
The following Microsoft Hyper-V versions are supported:
Microsoft Hyper-V Server 2012 R2
Microsoft Hyper-V Server 2016
Windows Server 2012 R2 with Hyper-V
Windows Server 2016 with Hyper-V
Ensure that you bring up fresh ClearPass 6.7.0 installs with the network adapter type "Network adapter" instead of
the legacy option.
i have both NIC as network adapter.
its a fresh built box we did not upgrade it.
Server 2012R2 standard
MVP Expert
Can you check if the have a static MAC address assigned to the VM? Hyper-V will do a dynamic MAC address by default sometimes. Changing the mac address on a linux based VM might cause issues.
Cheers, Frank
AirHeads MVP Expert |AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
it has dynamic mac address .
do you want me to change it to static?
MVP Expert
Yes and then check again if IP address is being removed.
Cheers, Frank
Hi there!
The same thing happened to me and searching the forums I found this solution.
https://community.arubanetworks.com/t5/Security/ClearPass-Hyper-v-loses-mgmt-IP-after-reboot/td-p/488584
After assigning the MAC statically on the HiperV, simply enter CLI and write (system refresh-network)
which requires reboot. Apparently the command remaps ethernet ports with the new MAC addresses
Luck!
Ricardo Luis Cañavate García - ACMP / ACCA / ACCP / ACDX#972
GrupoTRC.com
