Clearpass & Cisco 3850 Switches interoperability
Hello Team,
We had configured Wired Web Auth with MAC Caching on CPPM with Cisco Switches. Everything is working fine with Cisco 3750x/3650... , Users are getting the Captive Portal automatically, Logs In, Posture etc.
We have the exact same config on new Cisco 3850 IOS XE 03.06.06 (Legacy AAA) & on Cisco another 3850 with IOS XE 16.3.7 (New-Style AAA). But the users are not getting the Captive Portal by default/automatically.  We have to manually type the URL, once we reach the portal, it's working fine same as the others.
Please note that we can see the URL under the auth sessions, but this model is not giving the auto-URL redirection. NAC config is fine since it's working well with older models as well as the new model is receiving the request under the auth session.
So, we are facing issue just with the auto-URL redirection. Is there any compatibility issues?
Suhylodakkal
