Highlighted
Clearpass and intune
Couple questions in the regards of CPPM and Intune extension.
Sysinfo: CPPM 6.7.9, cluster of two nodes. Using intune extension v4.0.0.
1) Any special considerations needed when deploying in a cluster?
For now I ran all commands following the latest guides on the publisher, I assume this is the way, but a bit unsure in terms of the extension IP.
2) Having the extension installed and added as an authorization source for the standard 802.1x CPPM service causes logins every so often to timeout.
Access tracker reveals:
Failed to get value for attributes=[OS Family].
Session failed for Host=http://172.17.0.2, Reason=[get::<easy_perform>, (error=56) Failure when receiving data from the peer].
[MS Intune Auth Source] - authorization took 30 secs
Whenever the timeout doesn't happen I can see the gathered intune attributes.
Accepted Solutions
Highlighted
Moderator
Re: Clearpass and intune
Did you install the extensions on all nodes in the cluster with the same IP?
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
Moderator
Highlighted
Nopes, thought it was enough that the publisher node had the extension running. Setting it up on both nodes seem to have resolved it.
Highlighted
Should I be using the same IP on boths nodes of the cluster or choose a new one for the subscriber?
Highlighted
I want to echo BobC's question.  I have 7 subscribers that I need to configure for the Intune extension (publisher is already configured).  Do I use all of the same Azure information for the entire cluster (tenantID, ClientID, and clientSecret), as well as the same IP address?  Based on sharing a single auth source it would make sense that all 8 CPPM servers would use the same IP address.
Highlighted
Moderator
The entire configuration should be the same on every node, including the extension IP.
Highlighted
Thanks Tim, our cluster configuration for Intune is complete.
Highlighted
