Highlighted
Frequent Contributor I
Clearpass insightdb join auth & radius_acct tables with session_id
I'm trying to access data in both the auth and radius_acct tables in the InsightDB however I am having an issue with the join.  In the auth table, the session_id is stored as a varchar however in the radius_acct the session is stored in a json array.
Does anyone know how to create a join between these two tables with these columns?
Example:
select session_id from auth limit 1
R00000000-08-5daac7ee
select session_id from radius_acct limit 1
{R01dfe002-12-5e7a3d5d,R03f6f208-11-5e7a3d21}
Accepted Solutions
Highlighted
Re: Clearpass insightdb join auth & radius_acct tables with session_id
The radius_acct.session_id is a text array. To reference the first element you can user radius_acct.session[1]. And the second using radius_acct.session[2], etc
I'm not great at SQL but this seems to work:
SELECT * FROM auth
JOIN radius_acct ON auth.session_id = ANY (radius_acct.session_id)
View solution in original post
All Replies
Highlighted
SELECT * FROM auth
Highlighted
Thanks that did it, so easy
