Highlighted
Clearpass w/ Juniper for dot1x
Hi There,
I'm trying to get 802.1x mac-radius working with Clearpass & a Juniper EX2200 switch and am not seeing any requests hit the Clearpass monitor logs.
I've followed this guide https://www.juniper.net/documentation/en_US/release-independent/nce/topics/example/nce157-example-aruba-dot1x-mac.html
I've attached the log output & config of the switch.
Thanks in advance.
Highlighted
Moderator
Re: Clearpass w/ Juniper for dot1x
Two suggestions, check in the event-viewer.... this scenario is typically because the NAD is not defined on CPPM either as a host/range/subnet.
IF a dot1X authN is hitting CPPM and the above is true then it will as you correctly point out NOT show in AT but should show in the event-viewer.
Best Regards
-d
ClearPass Product Manager
Highlighted
Hi Danny,
Thanks for the reply.
That's the strange bit, I don't get any errors in the event viewer & the device is configured using its host IP.
I've setup a new "device" for the entire subnet and I still don't get a hit in the activity logs.
Any further suggestions?
Highlighted
MVP Expert
What is the radius source IP configured on the switch ?
This is the command:
set access radius-server [CLEARPASS-SERVER-IP] source-address [SWITCH-IP]
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
Hi Victor,
Thanks for the reply!
access {
radius-server {
192.168.2.95 {
port 3799;
secret "$9$s22gJUjqTF/wYgJ"; ## SECRET-DATA
source-address 192.168.1.8;
profile Aruba-Test-Profile {
authentication-order radius;
radius {
authentication-server 192.168.2.95;
options {
nas-identifier 192.168.2.95;
accounting {
order radius;
