Contributor I
Clearpass with 3 diffrent domains (forests)
Hi I have a question from our client:
Info
Client has 3 diffrent domains (forests)
He wants to use Clearpass for authenication.
3 diffrent CA for each domain (forest)
Require EAP-TLS authentication method
Questions:
a) Can clearpass using service certificates function install each domain CA's server certificate?
2) Does client first must configurate his infrastructure for  forests cross trust, than define new root CA  with 3 subordinate CAs for each domain?
3) What are other options?
Re: Clearpass with 3 diffrent domains (forests)
A) yes
2) no, this is not required. You just need three auth sources, one for each domain.
3) nothing else is required
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
