Clearpass with AD connectivity issue
Hello Airheads!
Is there any trigger available in clearpass that can detect and alert if Active Directory is unreachable during client auth?
Thanks!
Re: Clearpass with AD connectivity issue
An event is logged to Event Viewer which can then be sent via syslog if configured.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Capalli,
can you confirm the required system event from below snippet? I can't trunoff AD to verify exact event.
Reqirurement is to trigger alert when Domain controller is unreachable
Frequent Contributor II
If the AD is not reacheable, we would see Authentication source timed out. If it is reacheable and having any failure's, we might see the other error.
-If you got what you need with my answer please give kudos and mark it as solution.
