Highlighted
ClerarPass CPPM scripting using Python
I would like to use Python module directly from CPPM to send in real time a list of authenticated users and devices (or any other attribute) to exetrnal server.
Is it possible to get access using CLI to CPPM and add a Python module to do that ? Could you help ?
How could I install a specific Python add-on ?
thank you for your help
Accepted Solutions
Highlighted
Frequent Contributor I
Re: ClerarPass CPPM scripting using Python
No. You'd have to run it as middleware.
View solution in original post
Highlighted
Moderator
the simplest process is to leverage context-server-actions to send a HTTPs POST to your 3rd party system, this can be event driven and you can pretty much include any data from the authN/authZ in the body, you can send it as xml/json eyc.
The key is having a system that can consume the data and can handle potentially a large number of API calls.
Best Regards
-d
ClearPass Product Manager
All Replies
Highlighted
Highlighted
Moderator
Best Regards
-d
