Highlighted
Clerpasss 6.8 Clustering Problem on ESXI 6.7
Hi There
I've got 2x instances of Clearpass 6.8, both servers are hosted by ESXI 6.7
Both Servers are in the same subnet and can be pinged on both ends from Clearpass CLI's
When im trying to add 2nd server as a subscriber ive got following Warning massage saying echo GET failed.
Has anyone expierienced similliar issue before ?
Regards
Jack
Accepted Solutions
Highlighted
Re: Clerpasss 6.8 Clustering Problem on ESXI 6.7
Hi All
Many thanks for all your comments
I can confirm that after upgrading to the latest version of Clearpass 8.2 clustering with ESXI 6.7 now works with a web gui and in CLI
Problem Solved !
Regards
Jack
View solution in original post
All Replies
Highlighted
MVP Expert
Is there a firewall between the clearpass nodes?
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Highlighted
MVP Expert
CPPM cluster (subscriber-publisher)
  • UDP Port 123 NTP (Subscriber to publisher)
  • TCP Port 443 HTTPS (Bi-directional)
  • TCP Port 5432 PostgreSQL for DB replication (Subscriber to publisher)
  • TCP Port 80 HTTP (Between Nodes)
  • TCP Port 4231 NetWatch (Post Authentication module and the node where Insight is enabled
check if all this ports are opened
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Hi There
Thanks for coming back to me on this.
Both Clearpass Servers are hosted by the same ESXI host
Also both servers are connected to the same Vswitch which is part of the same Vlan connected to Aruba Switch, there is no firewall in between the servers.
Are there any other ways to troubleshoot this issue ?
Many Thanks
Jack
Highlighted
MVP Expert
Are the HTTPS certificates valid and is the time correct on both machines?
Highlighted
HI There
HTTPS Certificates are on default (Out of the box) and Yes time is correct on both platforms
Best Regards
Jack
Highlighted
MVP Expert
MVP Expert
Make sure you using exact same software release on both nodes, is NTP configured and use the same cluserpassword on both servers.
If nothing work, pleas create a tac case.
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Highlighted
Yes, i think ive tried everythig and yes both of them are in the same version 6.8.x
Highlighted
Hi Jack,
Just wondering if you had any luck from TAC on this? I have the exact same issue on two of my boxes (on 6.8.1).
Alexander.
University Information Services
University of Cambridge
Highlighted
Frequent Contributor I
I have tha same problem on ESXi 6.5. My clearpass VMs are on the same subnet, have you resolved the issue?
