MVP Expert
Configuring Mobility Controller RADSEC
I've been using RADSEC for a while in conjunction with FreeRadius or RadSecProxy and thought I'd try configuring it on a Mobility controller so ...
Have uploaded all the appropriate CA chains and server cert
Generated a client cert to use on the controller
Defined te shared key as being radsec
Created a RADIUS server and enabled RADSEC ( incidentally, by default doesn't seem to let you specify a server cert from the GUI without doing some CLI stuff first)
Applied and saved the config .... and looking at the RADSEC server can;t see any RADSEC tunnel establishment requests attempts yet.
Haven't pointed any auths at the RADIUS server yet. Does the tunnel come up automagically or only after it sees an auth request for that RADIUS server ( guess it'll be the latter)
Anyway of forcing a RADSEC tunnel establishment for testing ?
A
Re: Configuring Mobility Controller RADSEC
If it's configured correctly, it will come up immediately.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
MVP Expert
o.k. might be a firewall issue between the mobility controller and the RADSEC server , didn;t want to play with clearpass RADSEC at the same time, another unknown quantity
A
MVP Expert
o.k. firewall stopping things.... moved to new server
so I've got radsec.york.ac.uk on the controller defined as . a server cert using a .p12 file called RADSECYork . I've also uploaded both the root and intermediate CA certs
From the command line I've typed
no radsec-trusted-cacert-name
and then typed
radsec-trusted-servercert-name RADSECYork
After which I get
Unknown Trusted Certificate. Please upload the certificate before configuring in the profile
but the cert is on the mobility controller
crypto-local pki ServerCert RADSECYork radsecyorkacuk.p12
Upload the root CA that issued the RadSec server certificate. Don’t do individual servers.
MVP Expert
Already there, both the root an intermediate in the CA chain
crypto-local pki TrustedCA UoYRoot UniversityofYorkRootCA2.cer
crypto-local pki IntermediateCA UoYIntermediate UniversityofYorkIntermediateCA2.cer
Mobility controller says cert CA is UoYIntermediateCA ( see image)
radsec-trusted-cacert-name <root CA for server cert>
MVP Expert
Running round in circles here
1). radsec.york.ac.uk installed on controller as a .p12 file without the CA chain
2). Root an intermediate certs installed on controller (PEM files)
In my RADIUS auth server I can specify the CA Root.
radsec-trusted-cacert-name uoyroot
If I then try and install the server I get a mesage
radsec-trusted-ca-cert-name is configured. Please unconfigure with "no radsec-trusted-ca-cert-name" and then configure "radsec-trusted-server-cert-name"
Note that this is wrong, it should be no radsec-trusted-cacert-name
If I then try installing the certificate radsec-trusted-server-cert-name radsecyorkacuk
I get the message Unknown Trusted Certificate. Please upload the certificate before configuring in the profile
But the cert is installed on the controller
This is on 6.5.4.8 BTW
Please work with TAC. I’m getting confused by your order of operations here.
MVP Expert
Yeah I'm running round in circles as well :-(
