MVP Expert
Correct settings for RFC3576 bind address in clearpass guest
I've a cluster of 2 nodes  (cppm 6.8.1)  and just need to check what the correct seettings for this value should be.
On the master publisher if I go into clearpass guest Airgroup config and set the interface to automatic and then go to Configuration/ Authentication I can set the ( normally 0.0.0.0) RFC-3576 bind address to the master publisher management address.
So for the whole cluster Airgroup CoAs would come from the Master Publisher mgmt ip address ?
Only ask because originally I'd set up Congih/Auth = 0.0.0.0 and the clearpas guest setting to be mgmt port.
On my Arubaos8 mm looking at airgroup CoA stats I could see airgroup requests coming in from all IP addresses associated with this cluster.
