MVP Expert
Custom fingerprint generation
I've had some success at defining custom fingerprints for devices e.g. Amazon Echo that has a different OUI to the ones defined in CPPM Fimgerprint DB
I've also had some failures .. e.g. defining a custom fingerprint for what I thought were a handful of devices ... and had a couple of thousand devices had their signature changed (on a test server!)
So what would be a good procedure to use for restoring endpoint fingerprint definitions back to pre changed values?
MVP Guru
Re: Custom fingerprint generation
Importing the backup of the fingerprints you took before making the changes. ;)
Cheers
James
MVP Guru
You can have a look at the API (https://<your.clear.pass>/api-docs/Dictionaries-v1#!/Fingerprint). There are some more operations like delete fingerprint available there.
MVP Expert
Doh! :-) Course you can.
Thx
MVP Expert
o.k. that's a bit cooler. I'll have a look
A
MVP Expert
o.k.
So searching for a custom ingerprint I've already created gives me
  "id": 100014,
  "category": "Home Audio/Video Equipment",
  "family": "Amazon",
  "name": "UoY Amazon Echo",
  "_links": {
    "self": {
      "href": "https://clearpass8.york.ac.uk/api/fingerprint/100014"
 but the bit I'm interested in is whats in the "self" section. Which I guess is the actual conditions that dentify this custom fingerprint. So how do I get that info ?
MVP Expert
... also .... when modifying a fingerprint ... need t oknow what goes into the body of the call....
