MVP Expert
Custom fingerprint question
I've got 2 GrandStream VoIP H8xx devices. When I saw the 1st one on the network. I did an Update Fingerprint/Add fingerprint rule, selecting the device OUI and dhcp options   and pointed it at the appropriate custom fingerprint. That seemed to work
Another Grand stream device appeared  except this one  had 2 dhcpoption55 values different to the 1st one, so I did . the same Add fingerprint again
Question. Will clearpass remember both of these custom fingerprint rules and map any devices that apear to the same Category/Family/Name ?
... or did the 2nd one overwrite the 1st one?
Rgds
Alex
MVP Expert
Re: Custom fingerprint question
And the answer is
in 6.7.8 downloading custom fingerprints only shows the 1st one created.
in 6.7.9 the download shows both the custom fingerprints
So
6.7.8 gives
<DeviceFingerprint category="VoIP Phone" family="GrandStream" name="HT8xx">
<FingerprintRules>
<FingerprintRule match-conditions="ALL">
<RuleCondition name="mac_vendor" operator="contains" value="Grandstream Networks, Inc."/>
<RuleCondition name="dhcp.option55" operator="contains">
<valueList>1,2,3,6,12,15,23,28,33,42,43,51,54,66,121,125,160</valueList>
</RuleCondition>
<RuleCondition name="dhcp.option60" operator="contains">
<valueList>HT8XX dslforum.org</valueList>
</RuleCondition>
<RuleCondition name="dhcp.options" operator="contains">
<valueList>53,61,60,124,125,50,54,55,82</valueList>
</RuleCondition>
</FingerprintRule>
</FingerprintRules>
</DeviceFingerprint>
While 6.7.9 gives
<FingerprintRules>
<valueList>1,2,3,6,12,15,23,28,33,42,43,51,54,66,121,124,125</valueList>
</RuleCondition>
</RuleCondition>
</RuleCondition>
</FingerprintRule>
</RuleCondition>
</RuleCondition>
</RuleCondition>
</FingerprintRule>
</FingerprintRules>
Sorted!
and just to confirm our Phone people plugged in more of these devices and the "just worked" . can;t be a bad thing :-)
MVP Expert
Sigh! stand corrected , 6.7.8 also shows both custom fingerprints
