Highlighted
Customer wants to use ClearPass and Azure MFA (Multi Factor Authentication) for Cisco anyconnect VPN
Customer wants to use ClearPass and Azure MFA (Multi Factor Authentication) for Cisco anyconnect VPN users. Can this be done with ClearPass? attached doco explians how it's done with Cisco ASA and Azure.
Highlighted
Moderator
Re: Customer wants to use ClearPass and Azure MFA (Multi Factor Authentication) for Cisco anyconnect
It’s likely possible, but it’s not something that has been tested so it’s not supported by TAC. I should also add that Microsoft's Azure MFA Server has been deprecated and is not available for new install.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
