- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DHCP relay vs Device fingerprinting (ArubaOS-Switch) in ClearPass profiling
3 weeks ago
Is there any difference in the information that the ClearPass obtains between DHCP relay method and Device fingerprinting feature on ArubaOS-Switch?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: DHCP relay vs Device fingerprinting (ArubaOS-Switch) in ClearPass profiling
3 weeks ago
I believe this feature was added in AOS-S 16.06 version. Once you have configured the switch
- to use ClearPass as RADIUS server,
- "radius-server cppm identity"
- device-fingerprinting policy
then the switch after the fingerpint analysis will send the info to ClearPass. This will not replace the DHCP relay (IP helper) functionality but is in addition to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
When you config CPPM as secondary DHCP IP helper-address then CPPM can do device fingerprint using DHCP request detail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
DFP on AOS-Switch is designed for static devices. You should continue to use DHCP finerprinting with DFP.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
a week ago
Would it be a problem to add this to each switch port? Because in some cases you cannot be sure on what port static clients are patched...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
