Regular Contributor I
DUR Separate Policy and VLAN
Using CPPM for Downloadable User Roles to 2930 switches. I can call en Enforcement Profile that has a Policy to set ACL and VLAN. Works great.
I would like to create seperate ENF Profiles. One to send Policy and another to send VLAN. Anyone know if this is possible? I have tried with no luck.
Example for a single authentication (two enforcement profiles called in the same enforcement policy condition)
- Send Allow-All Policy
- Send VLAN 123 Policy
This would allow a device to connect with full access and be placed on VLAN 123.
This would be great as I can then just have a single Enforcement Profile for Allow-All and individual Enforcement Profiles for the VLANs. This would then allow me to mix and match different enforcement profiles during a single condition (such as a more restrictive ACL) with the VLAN profiles I already have.
Today I need to create seperate enf. profiles for each combination
AMFX #69
Re: DUR Separate Policy and VLAN
No. A DUR is one object.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Thanks. I figured so but thought I would ask.
AMFX #69
