Highlighted
Default Wireless - Azure AD - SAML Provisioning Settings
Hi All
I'm not sure if anyone has come across this while trying to configure Azure AD as an authentication source? I'm following the 2018 guide and it references what looks ot be a pre-installed provisioning setting?
Would the reason I can't see this because we're trialing this on an evaluation licence? Would anyone know whether it be fine to amend the default settings with what has been suggested?
Regards
Ben
Highlighted
Moderator
Re: Default Wireless - Azure AD - SAML Provisioning Settings
You need to create a provisioning setting like any other Onboard flow.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
