Doubts about Insight ?
I have some questions about ClearPass Insight ?
Does it have a separate database or it relies on other databases queries to generate a report ?
Does it store data from other databases like Endpoint, Guest and Tips all the time in a separate database or it queries those databases during report generation ?
Let me explain why I am asking thoses questions.
We have a client with 90-day Insight database retention that generates a Category Auth report by ClearPass on the first day of each month. We also use the Endpoint database to provide Mac caching for Wi-Fi users.
The database cleanup interval is set to 0 day. I understand that 0 days means that this database is never cleaned. Currently there are 20,000
entries in the database and next week a new WiFi Guest will be activated and about 2000 new users will be added to this database every day. To not increase this database too much I want to configure the cleaning interval for 7 days.My fear of changing this is the impact that may be generated on Insight reports. If Insight queries information from Endpoint database in real time I will lost the historical data.
Probably Endpoints database is not being used for my Insight reports as I am using Category Auth report by ClearPass. Maybe Acess Tracker database (Tips ??) is being used. Is it correct ?
Thanks and Regards,
Luis Rodrigues
MVP Guru
Re: Doubts about Insight ?
ClearPass has tipsdb, insightdb and tipslogdb databases.
Endpoint data will be stored in tipsdb.
We have endpoint table in insightdb aswell, retention setting in cluster wide parameters is applicable only to tipsdb, insight db retention is present in insght UI>Adminstration seciton. Defualt it is set to 30 days.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hi Pavan, thanks for the answer.
So If I understood I can clear Endpoint database without losing the historical information from Insight. Is it correct ?
I changed insight database retention  to 90 days. If I delete the endpoint database every 30 days Insight will keep the endpoint copies that are deleted ?
Rgds,
Luis Rodrigues
MVP Guru
Yes, still you will have endpoint details in insight database.
Pavan
