Force SMTP traffic over Management Port
Hello everyone.
I´m implementing a clearpass server using both, management and data ports.
Since the SMTP server is reachable just over the management network i need to redirect the SMTP request to this port.
Is there a way to do it ?
obs: at this time i can see the traffic going out over the data port when i send a test e-mail.
Thiago
Re: Force SMTP traffic over Management Port
No. Generally speaking, if you’re going ot use both interfaces, they both should not have default routes to the internet.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hello Tim
Thank you for your quick answer.
I will configure a static route to the smtp server. This should work according to the attached documentation.
regards,
Thiago
