I'm attempting to accomplish the exact same thing.
Did you ever get this to work?
Shane Graham
Original Message:
Sent: Oct 30, 2019 05:11 AM
Subject: Guest Device Repository Authentication using PAP
I am working to setup Meraki iPSK with CPPM. Meraki passes the MAC address using the PAP Authentication method.
I have it working using the Endpoints Repository, but if I try to authenticate against the Guest Device Repository it fails with "RADIUS PAP: CLEAR TEXT password check failed"
Here are the two services:
Endpoint ServiceGuest Device Service
Is it possible to use the Guest Device Repository for MAC authenication using PAP?
Thanks in advance,
Nigel
