Frequent Contributor I
Guest issue from different VLAN
I'm trying to move my guest network to a different VLAN/subnet.
This worked fine on OS 6.5, but I cannot get it to work on 8.3.
The registration page pops fine, the login page pops fine, the login will not process after entering password. The browser keeps telling me that I need to connect to the website.
I know I must be missing something.
Thanks.
Re: Guest issue from different VLAN
Unfortunately, there is not enough information to determine what your problem is.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor II
This could be any number of things. You need to first include information such as if you are using CPPM or internal captive portal.
Sounds like you are not handling the radius/webath request back but it's hard to say without a lot more context.
MVP Guru
Are you hosting the captive portal on the controller or it is external ?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Are you trying to perform COA when you mean change guest vlan?
Or are you performing a change to the interface setting for the VLAN used for the guest network as in moving it from vlan 10 to vlan 20 for example?
Ajay Kumar Ravipati
ACMA (V8) | CCENT | CCNA (R&S)
