Huawei phones not getting connected to Guest network on Aruba AP & Controller
Tested multiple Huawei brands of phones to connect to guest wifi after entering sponsor email and login email.
and getting accepted from sponsor it giving an error
authentication failed.
Tested the same scenario on a couple of Huawei branded phones.
Is it belong to DHCP fingerprint or something else?
Re: Huawei phones not getting connected to Guest network on Aruba AP & Controller
Hi
Im having a similar issue a at a cleint.
Huawei devices just goes back to the login screen and registering
are you using https or http ?
I was using http for now till we get the ssl cert sorted, so i just wanted to know if when i load the cert and use https. This will be resolved
Occasional Contributor I
mostly Certification issu, i faced same this issue before.
