Contributor II
IAP External captive portal - authentication text
I have a working setup with IAP and external captive portal using the Internal radius DB to authenticate guest/guest. This is my current form code:
<form method=POST action="http://securelogin.arubanetworks.com/cgi-bin/login?">
<input name=user value="guest" type="hidden">
<input name=password value="guest" type="hidden">
<input name=cmd value="authenticate" type="hidden">
<input name=mac value="" type="hidden">
<input name=ip value="" type="hidden">
<input name=essid value="" type="hidden">
<input name=url value="http://www.google.com" type="hidden">
<p align="center">
<br><input type="submit" name="Login" value="ACCEPT" class="button" />
</form>
But I would like to use Authentication text instead of using the Internal DB. How should I modify my HTML code to make it work with Authentication text. The idea is that the guest just has to click the accept button after reading terms and conditions. I've been trying all documentation I was able to find online, for some reason I can't get it to work ....
Re: IAP External captive portal - authentication text
Hi gvandaal,
I did this setup some years ago, but it should still be valid. I have documented it here:
https://www.flomain.de/2016/12/aruba-instant-with-external-captive-portal/
BR
Florian
visit our Youtube Channel:
https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ/featured
Please visit my personal blog as well:
