Integration Clearpass with EPON switches
Hi Team
I have our customer with EPON switches, I need integrate these switches with Aruba Clearpass with 802.1x, however  I don´t found documentation and use cases with this technology.
I have these questions:
Is posible this integration?
Aruba Networks can certificate this integration?
What is the limitation with EPON switches?
What should I consider?
The Aruba TAC support this issues with this integration?
Team, Thanks for your  help.
Regards
David C.
