Issue ClearPass's Services to WLC Cisco
Hi All,
I have some issue integrate ClearPass Guest with WLC Cisco (Firmware version 8.0).
On Input Radius Request show like picture on below
I am confusing, from the picture show "Radius:Aruba:Aruba-Essid-Name & Aruba-Port-Id".
Can you help me to explain about this? Because I used  WLC Cisco, i think i will get some parameter airspace (not Aruba).
MVP Guru
Re: Issue ClearPass's Services to WLC Cisco
How did you configured the guest page vendor settings ?
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
The access device is localhost. This request does not appear to be coming from a NAD.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hi All,
I have fixed this issue.
I try do disable and enable the dictionary Airspace and re-enter my Device WLC Cisco on Network Device.
Thanks.
