We have configured dot1x authentication on Juniper EX switches and ClearPass as a RADIUS server.
Here the problem is by default the switch port is in one VLAN and the domain machine will authenticate in that VLAN only and once the user is logged into the machine, based on the user department the port will be moved to respective department VLAN.
However, in Access tracker showing the respective VLAN role is assigned the show VLAN command showing the port is moved to respective VLAN. But the user is not getting IP address from the VLAN pool from DHCP server and once we do release and renew then only user is getting an IP address. Even we have added Avenda-tag-id: 0 in the enforcement profile.
Can anyone help us on this issue.
Yugandhar.
