Contributor I
MAC Authorization with 802.1x Wired or Wireless service
I would like to user MAC authorization with 802.1x service thus if both user (AD user ) and pc (MAC in white list NOT memeber of AD) authenticated , allow access.
- How can i use MAC as Authorization source with 802.1x Service ?
- Can i add MAC as username and password in local users and then use Local User Repository in authorization tab ?
- How would be the rules of enforcement policy , can be somthing like authorization AD, memeber of group X.
And
authorization Local User Repository, role name = Y
Re: MAC Authorization with 802.1x Wired or Wireless service
Why use MAC address when it can be spoofed? EAP-TLS is recommended to solve these use cases.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Contributor I
Because PCs are not member of company domain.
Is above applicable ?
MVP
MVP
You could use the ClearPass Onboarding to achive this, but its licenced.
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP - Was this post usefull, Kudos are welcome.
Contributor I
I am looking for a method other than on board.
can any one help ?
MVP
MVP
Hi Sultan77,
A device does not necessarily have to be AD joined to use EAP-TLS.
First of all, the CA-Root (and intermediate) certificate must be installed on the endpoint in order to validate the Clearpass Radius Server certificate.
In addition, a computer / user certificate must be installed on the endpoint of your own PKI infrastructure.
Clearpass must have the CA-Root (and intermediate) certificate with which the endpoint computer / user certificate is created in its trust store to be able to validate the computer / user certificate.
I think the biggest challenge is that it requires a high management effort. You must also be able to issue PKI certificates to "unknown" endpoint devices, which can be a security risk.
I wonder if other people have another solution in mind here.
Configuring unmanaged devices for 802.1x can also be a chore, as well as maintaining lists of mac address to users.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
Hi CJoseph,
How can i use MAC authorization and 802.1x authentication ?
To allow specific MACs to specific resources.
MVP
MVP
You can create a extra attribute field in the endpoint database and use this endpoint database attribute in your enforcement policy.
