Mac spoofing for same device category
Hello will clearpass be able to detect profile conflict if I spoof the Mac address of Hp laptop with same OS to another Hp laptop with exactly same OS.
In this case device category will remain Computer so will there be a conflict ?
Frequent Contributor II
Re: Mac spoofing for same device category
I think it all depends on the fingerprint. It could be that the 2 devices are using other fingerpints but both show up as a windows 10 computer.
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
The profile conflict is on basis of category only ? If this is the case , cppm fail to detect conflict
