Highlighted
Machine Authentication for Linux
Hi all,
we are doing 802.1x for Windows using both machine and user auth. We need to do the same scenerio for Linux as well. User auth ok but I cannot grab machine auth role (even request) from Linux anyway (logout&login, reboot laptop, everything tried). Is there any way to do this? No documents have been found.
Accepted Solutions
Highlighted
Moderator
Re: Machine Authentication for Linux
Yes, it's generally a system level config.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
Moderator
Machine Auth is a Windows construct.
Highlighted
Thanks for reply, Tim. Do you know how they act when client logged out? Might Linux not need to send authentication request again? I have tested for a few Linux and seen they stayed connected even if logged out. This is general behavior for every version of Linux according to your experience?
Highlighted
Moderator
Highlighted
Cheers mate, useful info.
