Highlighted
Regular Contributor I
Management address for 7210 interface
I have a 7210 - I want to give it a management address to a dedicated interface. Couldn’t see a dedicated management interface but wondered if there’s a way to config it anyway?
Accepted Solutions
Highlighted
Re: Management address for 7210 interface
You would just give a VLAN an ip address and then make that  vlan your management interface:
https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/content/arubaos-solutions/1cli-commands/controller-ip.htm?Highlight=controller-ip
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
View solution in original post
All Replies
Highlighted
