Contributor II
Max Local Users Size?
Is there a maximum size to local users? Or is that only constrained by the hardware for Clearpass?
Looking at using local users as a database to provision RAPs.
My other option that I can think of is hosting the DB outside of Clearpass and creating a source that queries it.
Moderator
Re: Max Local Users Size?
The RAP whitelist offload feature uses the endpoint database, not local users. There is no limit on size.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Contributor II
Awesome. I must have misread the doc I was reading! thanks
