Contributor I
Migrating from clearpass hardware to virtual
Hello All,
just checking before I proceed,
I'm planning to migrate a clearpass hardware to VM, so my question is simple: is it OK to backup the config from CP-HW and restore it in CP-VM?
thanks.
Frequent Contributor II
Re: Migrating from clearpass hardware to virtual
Yes, you can copy the backup and restore on VM.
-If you got what you need with my answer please give kudos and mark it as solution.
Aruba
You will also need to back up the server certs (https,radius)
Thank You,
Troy
Contributor I
all great replies, thank you so much
I confirmed to my end customer that we can proceed =)
