Contributor II
Mobility Controller not sending TACACs logins to ClearPass
Hi all,
I am trying to setup TACACs authentication against ClearPass on a Mobility Controller running version 6.5.4.6.
I might be missing something, but it seems the Controller is only attempting to authenticate users locally. I've confirmed this by doing a 'show log security' and there is no evidence that the Controller is passing Authentication Reqests to ClearPass.
My configuration for AAA is below:
ip tacacs source-interface vlan 10
aaa tacacs-accounting server-group ClearPass-TACACs command all mode enable
aaa authentication-server tacacs "aruba-cp-01-TACACS"
   host "10.0.10.11"
   key 785ee4a4bce8e3c104ff01e1b681fbdb5c028851fbe3e296
   session-authorization
   source-interface vlan 10 ip6addr ::
aaa server-group "ClearPass-TACACs"
 auth-server aruba-cp-01-TACACS
aaa authentication mgmt
Any ideas?
-Brett
Contributor II
Re: Mobility Controller not sending TACACs logins to ClearPass
Fix was simple. Hadn't enable the AAA configuration:
enable
