PALOALTO VPN with CLEARPASS using CHAP auth
Hello does someone had an issue with PALOALTO VPN and CLEARPASS using CHAP authentication?
Info
Clearpass RADIUS servise for PALOALTO VPN
Authentication method: CHAP
Source : Active Directory
During authentication error 209 occur
Error Message: No password in request
RADIUS CHAP: Clear text password not available
I also add full  service configuration and source configuration.
Maybe it is not possible to authenticate user from PALOALTO in Clearpass (Active Directory) using CHAP authentication?
Re: PALOALTO VPN with CLEARPASS using CHAP auth
You cannot use CHAP with Active Directory as authentication source.There is no authentication mechanism in AD that supports RADIUS CHAP authentication, you need to use PAP or MSCHAP/v2 to get it working.
Thank you,
Saravanan Rajagopal
**Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the post.
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
