Frequent Contributor I
Palo Alto Using Clearpass Radius for Admin Login
I've configured both the Clearpass and Palo sides of the RADIUS auth as
per articles posted by Aruba and Palo.
When I try and login using my AD credentials its rejected by clearpass with the error below.
Please could you give me some ideas why this might not not be working and any help would be much appreciated.
Jon
Error code 106
Error Catagory Internal error
Error Message Internal error in RADIUS server
Alert for this request
RADIUS Cannot select appropriate authentication methid
Moderator
Re: Palo Alto Using Clearpass Radius for Admin Login
sounds like the auth-method is not enabled with in the service-policy.
Best Regards
-d
ClearPass Product Manager
