Queries related to wired nac deployment
Hello ,
i have three generic questions  this query is for Wired LAN
 for Wired computers laptops and desktops which is primarily for corporate users using machine authentication + printers
supplicants ; Wired Laptops/Desktops , Printers , Authentication server (RADIUS) is CPPM , Authentication store  AD
1) is it possible to have automatic NAC enrollment for users who dont have certificate or any self portal we can intergrate like amigopod or any third party ?
2) how do we allow PXE boot for machines which have the certificate or which dont have ?
3) kindly provide some use cases for wired if you have
Thqnks in advance
regards
Re: Queries related to wired nac deployment
Did you take a look at the ClearPass Solution Guide for Wired Policy Enforcement?
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hi Tim ,
Yes i understood the basics as i am new to Aruba .
but there is less explantion for PXE boot and use cases for Wired
If you can provide high level view for my 3 queries i will work further in that direction
All of the use cases are covered in the doc.
Regarding PXE, this is a device profile type so you can write policy against that and layer on auth method.
Thanks Tim , if you have some specific use case for wired captive portal or pxe please share.
I have gone through the use cases,
