Frequent Contributor I
Re: Radius COA problem between controller and clearpass
thanks for your reply
I just changed all the passwords, test with another enforcement policy and profile, with another controler, with another service etc ...., i think i have tested all that i could :)
Yesterday i have opened a case, i'm in waiting to reply from them.
Thanks for your help, Happy Holidays
Regards
Yann
For your information, my AP is in RAP Mode and the VAP is in Bridge mode
I just configure my VAP in tunnel mode and  the CoA works good now !
My question : is there  a prerequisite of works for CoA in bridge mode ?
regards
Yann
Trusted Contributor I
thanks for reporting back about your finding. sounds like a possible reason for it not working. tried to find a source saying this is indeed the issue, but can't find one. hopefully your ticket with TAC will give  a definite answer. be sure to relay that.
Yann Dorval,
What version of ArubaOS are you using?
Are you sending radius accounting information to clearpass?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Hi Cjoseph,
The Version 6.4.2.2 is install on controller.
Yes, i send the radius accounting information from the controller to clearpass.
Regards
Yann
I confirm, with one CAP on the VAP in tunnel mode,it's works well, but when i configure the VAP in bridge mode, i have the message "Session-Context-Not-Found"
what is TAC saying about this, is there no way to pull this off with a bridged SSID?
Hi Boneyard,
yes, they answered me ... "CoA will not be supported in the bridge mode", it's a big problem for my project ...
Thanks you for your help
