Frequent Contributor II
Required Certificates for Onboard with MM
HI community we are planning to implemente ClearPass Onboard for our network. This is our scenario:
1. 1x ClearPass server.
2. 1x Mobility Master.
3 . 62 x 7210  Aruba Controllers (distribueted in different sites).
As I know we need a public signed ssl certificate for ClearPass (Onboard provisioning page).
In a previous deployment we implemented this configuration with IAP and we needed to install another ssl certificate for the virtual controller in order to avoid securelogin.arubanetworks.com issues.
So the question is, ¿Do we need different ssl certificates for every controller (62 controllers) or just one for the Mobility Master?
Thank you in advance.
Daniel Méndez Vargas
ACMP, ACCP
Re: Required Certificates for Onboard with MM
No. A single name certificate with a generic CN can be used on all nodes (example: captive-portal.yourdomain.com)
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Thank you so much Tim.
ACMP, ACCP
