Stateful 802.1x for Instant APs with upstream wired authentication
Hi Airheads,
Does anyone have an example of where wired stateful 802.1x is configured to allow an Instant AP onto the network, and still allow bridged clients onto the network?
MVP Expert
MVP Expert
Re: Stateful 802.1x for Instant APs with upstream wired authentication
details depend on switch manufacturer and model.
On a Procurve/Aruba Switch you could use Port based access control.
AP opens port and other clients on same port get through.
Details can be found in "Access Security Guide"-Manual of these switches.
Regards, Jörg
Please give kudos, if you like my post.
Please Accept as solution, if my post was helpful.
