Highlighted
Contributor I
Termination Cause: Port-Error
Hi Experts
I have some problems,
Why is it when I get the following error message?
What should I do to fix it?
Is the problem in the switch HPE 5130?
On the IETF page it says the following:
Carlos Villanueva
Highlighted
MVP Expert
Re: Termination Cause: Port-Error
You need to work with switch team to narrow down this issue, it look issue with switch port.
check show logs in access tracker for more details.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
