Highlighted
Two antivirus for posture policy in clearpass
Hi all,
I have one situtation in my office. Now they are planning to migrate one antivirus to another antivurs. And they will migrate bath by bath.
I just want to know can we add two antivirus name in one posture policy? Or is there any better to approach this situation?
We are running on Clearpass firmware 6.6.10
Thanks.
Highlighted
Re: Two antivirus for posture policy in clearpass
Yes, you can add multiple Antivirus check in the posture policy, Onguard is smart it will check if anyone of the antivirus is available, then the agent will mark the client as healthy. So, this way even if you do partial change on the network, it would still work and clients will still be secured.
-If you got what you need with my answer please give kudos and mark it as solution.
