Highlighted
Two factor auth with AD + MS Authenticator
Hi Team,
A customer plans to implement two factor authentication (AD + Microsoft Authenticator) for device administration. Can you please suggest whether ClearPass can be integrated with Microsoft authenticator (not Azure AD) to provide 2nd factor authentication when administering network/security devices.
Many thanks in advance!!
Highlighted
Moderator
Re: Two factor auth with AD + MS Authenticator
Azure MFA server can used via Token Server configuration.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Hello, do you have any configuration example by any chance? I have this escenario right now however I cannot get the interactive keboard to work...although the push up notifications work. Thanks in advance!
