Highlighted
Using 2Fa to log into clearpass admin GUI
Is this possible ?
A
Highlighted
Moderator
Re: Using 2Fa to log into clearpass admin GUI
If your identity provider supports it as part of an existing auth flow, yes.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Sigh!
Course that’s the answer Doh!
Senior moment
Thx
Sent from my iPhone
