Contributor I
Using Airwave to backup ClearPass
Can we use Airwave to take ClearPass backup?
MVP Guru
Re: Using Airwave to backup ClearPass
That is not a feature of Airwave. You can use the scheduled backup from ClearPass to create automated backups and send them off to an external server via SCP or SFTP.
