VIA loads before WiFi connects
Using the VIA client on windows 7 build to VPN end users into our network. The VIA client auto loads on start up of windows and I notice it loads and tries to connect to the network before WiFi has connected to the Internet.
When the VIA loads and can’t get internet access (because WiFi doesn’t connect quick enough) it just spins and says its loading.
Can we somehow delay the load of the VIA software for a certain amount of seconds or force it to wait for proper internet connection?
