Regular Contributor I
Viewing dropped guest authentication sessions in CPPM
Is there a way in CPPM, either web GUI or CLI, to see authentication logs containing the reason for de-auth or other reason for connection loss? I'm seeing guest user sessions get terminated at random times, and I can't figure out what's causing it. We are using captive portal with MAC authentication for guest access. Access points are IAP-305 and IAP-315. Testing with iOS (iPad) and Android devices and, althought the two vary a little, they both will display this behavior. Specifically, the iPad will lose connection when it goes to energy-saver mode and forces a re-authentication to the guest network. I Android device doesn't do that, but if I physically change location, it will discconnect (this is in a small office and I'm not leaving the building - just going from one room to another, always within twenty feet of the AP, sheetrock walls, no cinderblock, rebar, etc.). Any insight would be appreciated.
MVP Guru
Re: Viewing dropped guest authentication sessions in CPPM
Home > Administration Support> Application Log in Guest portal and Access tracker log in Monitoring » Live Monitoring » Access Tracker provide details.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
