Wired Captive Portal
How to configure captive portal in aruba switch 2930F?
MVP Guru
Re: Wired Captive Portal
See Chapter 5
https://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-a00061584en_us-2.pdf
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Hi Craig - that link doesnt work, at least for me.
The requested URL /km-ext/kmcsdirect/emr_na-a00061584en_us-2.pdf was not found on this server.
