Highlighted
Wired deployment query
I have a specific query for a customer.
They have a common vlan for laptop,printer ,camera and creating separate vlan is not an option for them.
Now eap tls is being proposed for laptops and rest all authenticate via mab . We use DHCP profiling and we will be using open mode for first 3 months .
My query as we are not doing vlan enforcement, what parameter cppm will return as successfull eap-tls or successful mab ?
We will be doing enforcement later after 3 months .but for open mode what is enforcement parameters or attribute even though enforcement does not block anything as we are using open mode and allow all initially
Highlighted
MVP Expert
Re: Wired deployment query
What type of switch are you using ?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
We have both Cisco and hope in the customer network
Highlighted
I mean hpe
Highlighted
MVP Expert
If you are looking for more visibility you can return a user-role per use case (laptop , VoIP , etc)
Thank you
Victor Fabian
Thank you
Victor Fabian
Highlighted
Moderator
I would recommend following the ClearPass Solution Guide for Wired Policy Enforcement.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
