Under Administration -> Operator Logins -> Servers
I have put in all the Ldap server information but I get the following error:
Authentication failed (username unknown)
I have also verified I can connect with the username password. I tested this by using ldp on the domain controller and I was able to bind and search.
I have tried various different settings but I Can't get it to work.
Attached is a screenshot of my settings.
Also,
The documentation for this is wrong.
It says
"Bind DN
The password to use when binding to the LDAP server. For an anonymous bind, leave this field empty."
The bind DN is not the password!
Any suggestions?
https://www.arubanetworks.com/techdocs/ClearPass/CPGuest_UG_HTML_6.5/Default.htm#OperatorLogins/CreatingLDAPServer.htm#kanchor549
